Gearing differences of the 3.03 ?
Discussion in 'General Maverick/Comet' started by Powerband, Jun 22, 2015.
  1. Powerband
    Powerband Member
    NY's \H/
    Any info or forum links to info on gearing of the 3 spd Toploader - 3.03 tranny appreciated ...
    I have a few from :a 170, 200 and a 250 . Read maybe sixes different from V8 3 Spd's ?? . .
    thansk
  2. Krazy Comet
    I dunno if I've ever seen a ratio chart, but it's not hard to figure out...
    Put trans in 1st gear and count how many turns of input are required to rotate output one time... Won't be exact but easy enough to tell 2.5 turns from 2.75, from 3, etc... Do same for 2nd gear...
  3. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    3.03 manual gear ratios
    2.99 first
    1.75 second
    1.00 third
    0.70 over
  4. rthomas771
    3.03 doesn't have overdrive...only 3 forward gears.
    They made 3 or 4 different cluster gears w/different gear count and lengths so I assume they were different gear ratios. Master Parts Catalog show that sometimes the cluster gear fits 6 or V8 and sometimes it fits V8 only.
  5. JoeB
    JoeB Member
    Stowe, PA
    Thanks, I can only say that it was early
  6. Krazy Comet
    Specs found on net but I can't guarantee accuracy... The 2.42 version was supposedly used behind big blocks, suspect that was trans behind 390 in my '64 Galaxie 500.. Was also used in some GM applications(mostly Pontiac), refereed to as the Dearborn transmission...
    3.03 Toploader ratios
    2.99 1.75 1.00 3.17
    2.79 1.70 1.00 ?
    2.42 1.61 1.00 2.33
  7. JoeB
    JoeB Member
    Stowe, PA
    From the web
    3.03 Small Block & I6 Transmission
    Ratios
    1st 2nd 3rd
    2.99 1.75 1.00
    3.03 FE Transmission
    Ratios
    1st 2nd 3rd
    2.42 1.61 1.00
  8. Powerband
    Powerband Member
    NY's \H/
    THanks for the discussion, I think the FE and L6/SBF differences are what I've heard about. I was curious if the L6 and SBF V8's applications were different but no one seems to think so ...
    have fun.
    ... but not too much:
  9. Krazy Comet
    Like I said, "not hard to figure out"...
