gear ratio for rear end
Discussion in 'Technical' started by Maverick_G.I., May 19, 2007.
  1. Maverick_G.I.
    Maverick_G.I. Maverick G.I.
    layton utah
    74 2 door 302 2brl
    I am rebuilding my rear end this weekend and i wanted to know what a good gear ratio was for my maverick if i was just gonna us the car for a daily driver and to play around in every once in a while my car is a 2 door 302 74 mav if any one has any ideas what gear ratio i should go with please let me know befor i get started tommorro
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    If you do much highway driving, you'll be happier with a high 3.XX, if you mostly cruise around town and make a few passes at the track, you'll be happier with a low 4.XX.
    my :2cents:
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    3.40 or 3.55 is perfect. I wouldn't go any higher or any lower, unless the primary use of the car is drag racing...
  4. Maverick_G.I.
    layton utah
    74 2 door 302 2brl
    thanks
    Yeah i was thinking a 3.73 but i wasnt sure if that was too high or not thanks for the imput though cause i do a good amount of high way driving
  5. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    ...or 3.70 if you have a 5th gear. Buzzing down the highway at 65 to 70 mph, my car is only spinning 2000 to 2200 rpm.:dancing:
  6. Jamie Miles
    Unless you have overdrive, or do absolutely no highway driving, I wouldn't go more then 3.55. My daily driver is a 3 speed manual with 4.56 rear gear. Interstate is totally off limits, but around town the car is awesome.
  7. stmanser
    Davenport, Iowa
    3.55 would be the best.
  8. scooper77515
    I have 3.80 and say that is really pushing it to the top limit if you do any highway driving. If I drove more highway, I would have stuck with 3.55, but I seldom do. And when I do, I don't mind driving the speed limit and running 3000rpms. It isn't SCREAMING, but definitely up there.
    BUT...when I want to pass someone:mischeif: :burnout:
    So, if more than 25% is highway driving, go 3.55 (we are talking 8" rear here, aren't we?), if less than that, go with the 3.80 since it is MUCH more fun in town and at the track(y)
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    What carb, intake, and cam do you have?
    Auto tranny?
    I ask because you can't just throw a 3.80 behind a stock 302.
    It will not help things unless your engine is comfortable making power at a higher RPM.
    Just a thought...
    Dave
  10. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    If your 302 is relatively stock or a mild build, a 3.25 is good gear. You'll notice big difference if your original was a 2.79.
  11. mean_maverick
    i would do the 3.55 myself, or at least that's what i plan to go with.... :)
  12. Maverick_G.I.
    layton utah
    74 2 door 302 2brl
    rear end
    i have an auto and i just recently got the mav a few weeks ago. i am the kinda guy who likes to work from the back to the front and save all the good stuff for the end. so i have not yet touched the engine but planned to in the near future. i plan to switch the 2barrel out for a 4 change exshaust mainfolds and then run duel exhaust. just the little engine things that give it a touch more horsepower till i convince my wife to let me spend more money. i think i am gonna go with the 3.55 since it seems to be what everyone is saying is a good gear ratio for the rear end. thanks guys.
  13. baddad457
    Ditto. The engine build has a lot to do with it. A big cammed motor will actually like more rpms at highway speeds and get better mileage than one that's choking under the powerband with a lower numerical ratio.
  14. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    3.25 unless it has overdrive, then 3.73.
  15. ratio411
    ratio411 Member
    Pensacola
    You mean 3.80?
