Gas tank to filler pipe seal
Discussion in 'Technical' started by karguyz, Apr 14, 2010.
  1. karguyz
    karguyz Member
    Hi All,
    Finally got tired of smelling gas all the time and stepping on the goopy drips on the garage floor from the front of the tank on the 72 Comet. We ordered a new 76 Maverick tank for the 72 Comet, along with the vapor vent valve and grommet.
    Haven't taken the old tank out so don't know the condition of the pipe to tank seal. The Mustang and Autokrafters sites all list a part number D1ZZ-9072 for years up to 1973. Nothing for later years. Of course the 74 and up were Pinto based and not REAL Mustangs.
    Does this fit the newer (76) gas tank, also? I hear that the filler pipe is smaller in diameter on later models because of the unleaded gas requirement. The Comet is hard enough to fill now with the regular (larger) pipe. I would like to keep the same pipe. Is the hole in the tank the same and the pipe necks down or is there a different seal size entirely for the later models?
    Tank is still on the truck from Rock Auto . I would order the seal now so we will have all the parts when it arrives but want to make sure it is the right one. No mention of this as I can recall on the various articles on tank swapping.
    The tank part number F30 on the Rock Auto site shows many applications, including Granadas and other cars. I could do a cross reference check for parts but somebody here must know.
    Thanks,
    John and Mikey, Comet jockeys
  2. maverick75
    i just happen to have one handy, but it doesnt have the part number :huh:
    it just says foMoco 98 on it.
    Maybe someone has an early seal and can measure it up.
    the measurements on this one are
    2 3/4" OD 1 1/8" ID
    and
    3" OD 2 1/2" lip to 1 1/8" ID
  3. 71gold
    ...tank to filler tube grommet/seal...
    ... '76-'77 tank w/'73 spout...
    the tank...p/n... f30...http://www.quantaproducts.com/products.asp?
    High quality Ni-terne plated steel gas tank with 3-year warranty
    Applications:
    Comet: 1976-77
    Granada: 1975-80
    Maverick: 1976-77
    Monarch: 1975-80
    Versailles: 1977-80
    Capacity: 19 gallons (Will replace 18 gallon tank)
    Dimensions: 28" x 26-1/2" 10-1/8"
    Original Part Number: D7DZ9002C
    Free with Tank: Rubber O-ring and lock ring for sending unit
    Packaging: Foam-wrapped, stretch-wrapped and boxed
    straps...p/n st-99...$30
    ...:Handshake...
  4. rthomas771
    D1ZZ fits Mavericks up to 5/1/75...E1AZ fits the 5/1/75 and later tanks inluding the Granada, Mustang II, 73-78 big Ford, LTD II, '79 T-bird & 73-79 Pinto, tank
  5. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    MAN! that 71 gold knows his stuff:bowdown:
  6. karguyz
    karguyz Member
    Thanks for all the help, guys. but my question still is, "Does the old filler pipe fit the later tank?"
    I will check with the local ford dealer. I should have ordered this seal (and the one for the floor) when I bought the other parts. For these small items the shipping is a killer. Maybe I'll just combine the order with a crate V8 to replace the six if I have to buy something from the stealer anyway!
    John and Mikey
  7. rthomas771
    ...:hmmm:...
  8. Rickringo
    Rickringo Member
    Houston, Texas
    1975 Maverick 2 door, 250ci.
    Where did you get the vapor vent valve and grommet? I bought a tank from RockAuto but they did not show the grommet. I need the grommet to put the tank in. Does it have a part number? The local Ford dealership here in Houston says that they don't have a part number listed for the grommet.
  9. mercgt73
    http://mmb.maverick.to/showthread.php?t=35490
  10. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Thats what I purchased on my 1974 Comet, F-30 an new straps to boot.I ordered the same filler neck seal on ebay. Larger fuel tank means a longer ride between stops.
  11. schroensr
    1975 Mercury Comet
    The part #is E1AZ-9072B for the maverick-comet after 1975. It was $16.95.
  12. anthony77
    anthony77 New Member
    Pointblank, TX
    Ford Maverick
    I saw your parts there, do you still have that bottom picture one with the 3" od, if so i am intrested in it, please respond back for a price, thanks
  13. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You do realize that post was three years ago right? I don't think he was trying to sell it any ways, just put it up for reference.
  14. 71Mavrk
    71Mavrk Member
    Nevada
    OK, first one to call wins.
    A few weeks ago there were only two. I bought one. I cound not find any others as much as I searched.
    D6DZ-9275-B NOS fuel tank sending unit for the 19 gal tank. (Double check the part number for your self)
    Green Sales $119.00
    Good luck,
    Micah
  15. Dave B
    71-73 Mustang, are the same, any Mustang place wll have them.
