Full Spool 8" Install
Discussion in 'Technical' started by mav5150, Apr 16, 2010.
  1. mav5150
    mav5150 Member
    Santa Maria, CA
    1975 Maverick (5.0 302, 5spd, Trick flow Track Heat, Floo Tek Heads, E303, 1.7 Cranes, Hooker Headers, Pro M meter, 70mm BBK TB, Electric Fan & H2O Pump, AC PS EV Delete, Stock '89 Bottom End) 1970 Maverick Grabber (Swapped 200 for 250)
    Installing a full spool. Right now I'm just starting with removing the pumkin and its not as simple as my 8.8 cover. Do you just unbolt around the outside and slide out? Mine is stuck good, so I'm thinking there is more to it.
  2. mav5150
    mav5150 Member
    Santa Maria, CA
    continued...
    just stuck...got it.
