fuel pump question
Discussion in 'Technical' started by BrianB, Dec 24, 2010.
  1. BrianB
    BrianB Member
    1973 Maverick
    Ok someone was helping me with the fuel system when i first got my 73. He thought the old mechanical fuel pump was bad so he put in an electronic pump(without the safety switch, and it doesn't seem to ever turn off). after that we noticed the line was clogged to hell and that was the problem but never put it back to the old pump. is there a lot that can go wrong with the mechanical fuel pump? and can i test it without hooking the lines back up to it:huh:
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    if the pump is still in the car put a hose to the pump and the toher end to a bucket or somthing and see if it sucks it up
    if it's out of the car just push down on the arm and if you hear a RONKING noise then it's good
    and they are only like 20 bucks for a new one (((GOOD LUCK)))
  3. BrianB
    BrianB Member
    1973 Maverick
    if i put my finger over it would i feel suction? or is that a bad idea
  4. timers
    timers Member
    richardson tx
    1974 maverick
    For some reason i've had to put two fuel pump on my 302 mav in the past seven years and i have clean tank and line. If it was me i'd just get a new pump. There cheap.
  5. BrianB
    BrianB Member
    1973 Maverick
    get a new mechanical? and how hard to install?
  6. 71gold
  7. BrianB
    BrianB Member
    1973 Maverick
    its on the fire wall it would take a few minutes to take it down
  8. 302-72-mav
    302-72-mav Member
    sactown CA
    go back to the manual pump
    just unbolt the 2 bolts from the stock one and pull it off
    then install the new one with the new gasket
    put the bolts back on the new one
    and run the hose's back to the new pump like it was before
    or if the old pump is good just try and run the hoses to there and see if it works ?
