fuel pump blues
Discussion in 'Technical' started by wgs226, Mar 11, 2012.
  1. wgs226
    wgs226 Member
    westminster colo
    1977 maverick
    hey i need to find out what the fuel pressure is from a stock fuel pump i just put on an edelbrock carb 600cfm 4bbl they (edelbrock) said if i have more then 6.5 psi in the line going to the carb i will have flooding problems when i shut the eng. down it was pouring gas down the carb untill pressure:bowdown: was released any one know what the stock pressure is on a mechanical 302 fuel pump is?
  2. darren
    Your fine with a stock pump. Mine runs around 5.5 psi.
  3. 71gold
    check float levels...and heat will do the same thing...
  4. simple man
    simple man Member
    Bunnell,Florida
    Sounds more like you have a little piece of crap caught in the needle valve! The stock pressure is 5 - 6lbs. If it was the pump pressure, it would flood all the time. (y)
  5. Joe Dirt
    Need a good fuel filter between the carb and pump
  6. darren
    I had a fresh rebuilt holley do that and it was a tiny piece of neoprene stuck in the rear needle valve. Must have come from the fuel line install at the carb. It only takes a tiny bit of debris.
  7. ptpdub
    ptpdub Member
    canada Sk.
    mine is 5.5 ish
  8. wgs226
    wgs226 Member
    westminster colo
    1977 maverick
    well i rented a fuel pressure gauge and found out my fuel pump is running 10 psi so i installed a fuel pressure regulator it cost 35 dollars at checkers thanks for all your input guys:burnout:
