Fuel pressure
Discussion in 'Technical' started by Racer_X, Oct 13, 2010.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    How much fuel pressure dose a 600cfm edelbrock carb need? the pressure regulator i have now goes up to 4psi. is that enough?
  2. Mavman72
    4 PSI for the E-brock should be fine,Does it fall on its face when you stand on it. If so...You can go to 6 PSI with the E-brock carb safely.
