Fuel Filter
Discussion in 'Technical' started by rickm, Mar 4, 2011.
  1. rickm
    rickm Member
    Owosso Mi
    Has any body ever put a see-thru filter in the hose that goes from the fender to the pump ? I was thinking it would catch all the crap that could be in your tank first. I ahve a seethru just in front of the carb and nothing is pumping in it now so I think I either need a fuel pump or my pick-up is pluged. I was going to blow in the line and see if it pumps then, which would mean get the tank cleaned, but if it doesn't I think I need apump and I would like to put a filter before it. Any thoughts Rick
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Those see thru filters are famous for burning cars up. They break.
  3. mavmet
    mavmet Member
    Auburn WA
    1972 grabber
    No gas flow
    Check your engine oil and see if it smells like gas or is reading high on the stick if the fuel pump went bad it could push fuel into the crank case just a thought it has happened to me in the past.
  4. rthomas771
    Running an extra filter puts extra strain on the fuel pump
  5. rickm
    rickm Member
    Owosso Mi
    All better, the float was stuck in the bowl and thus no gas.
