Fuel evaporator canister
Discussion in 'Technical' started by 429CJ, Aug 10, 2006.
  1. 429CJ
    429CJ Member
    New Philadelphia , Ohio
    1971 Black Grabber 1971 429 Cobra Jet Torino 1994 Mustang GT Vert 5 spd 2002 Mustang GT Vert. Auto. 2004 Cobra 510 RWHP
    Did the 71 Maverick 302 have a charcoal canister for the fuel system under the hood , if so are they hard to find.
  2. mean_maverick
    Yup, They Did. Located Behind The Passenger Side Shock Tower, Bolted To The Firewall. Just A Little Round Container About 6-7" Wide... Cant Miss It
  3. stmanser
    Davenport, Iowa
    i have one in my 71... one of the lines is broken.. the larger cloth/carboard hose... and then there is a hose going back to the tank on it.. i was thinking of taking it out.. not sure if it really works. or useful..
  4. MikeG747
    MikeG747 Member
    Arkansas
    71 Grabber wouldn't take gas. Unhooked the vent line from the Canister & now it takes gas. Guess the Canister was clogged.:huh:
  5. blugene
    Would you sell it?
  6. 429CJ
    429CJ Member
    Thanks for the information I guess I will have to find one , I still need that , an air cleaner assy. ,and original valve covers to get back to stock condition.
  7. Mavaholic
    THe large cardboard tube is still available from Ford. Part# D4ZZPD667A
  8. mean_maverick
    I Bet I've Junked A Dozen Of Those. Every Now And Then You'll See One Pop-up On Ebay But I'd Say Someone Around Here Will Have An Extra
  9. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Every Maverick came with the charcoal canister ... so any junker should have one ... make sure you get the bracket as well if your's is missing. Keep in mind that a 71 would have had the short version ... about 5 inches high ... pretty sure later year cars had much taller versions ... but either one would work.
    Good luck on the 71 302 air cleaner ... it was also used on 71 302 Mustangs ... If you don't care about having the correct air cleaner I have one I can sell you. The Snorkel and top are original paint and the base is the old one off my Grabber. The correct 71 cleaner may be tough to find ... it was on used only in 1971 and only on Mustang and Maverick 302 cars.
  10. Dave B
    Did the value covers say "Powered by Ford"? If they did I have a few spare sets kicking around, and may even have a cannister somewhere.
  11. dmhines
    Cumming, GA
    Yes ... they should say Powered by Ford ...
  12. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    Tired of the gas smell in the garage, I went ahead and got a black smaller plastic canister from a later model ford at the junk yard, workd/looks great and no smell.
  13. Jamie Miles
    Always one of the first things I remove and toss when I get a Mav...
  14. Mavaholic
    Not the best thing to do. It does not rob any hp and it safely vents gas fumes back into the engine to be burned,
  15. Blk70mav
    Blk70mav Member
    Galt, CA
    But what if you have a open element air cleaner? Where would you hook it up? My only guess would be to hook it up under the air cleaner base.
