Front wheel back spacing
Discussion in 'General Maverick/Comet' started by jski, May 24, 2014.
  1. jski
    jski Member
    Moyock, North Carolina
    There are dozens of threads regarding wheels and tires on here but i am having a hard time determining for sure what back space would work on the front of my 70.
    I want to run a 15x7 with a 225 60 15. I have seen threads with guys running everthing from 3.5 to 4.5 bs.
    Is anyone running this combination and exactly what offset/backspace are you running with no rub issues.
    The wheel database on this site is good but it needs a column to list the rim backspace too. That is important in determining just how big you can go and what will and will not fit.
    Any help would be greatly appreciated. I dont want to order rims and tires and not have them fit or rub......
    Thanks,
    John from NC
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You need a 4-1/4" backspace.
  3. jski
    jski Member
    Thanks
    Thank you for your response.
  4. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    That is the exact wheel and tire size on my 75. It has oem magnum 500's. I think the original back spacing for those was 4 1/4.
  5. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    On my 17x8 up front I have 4.5" BS. No rubbing issues 235-45-17
