Front to Rear Brake Line Question
Discussion in 'Technical' started by Tlowery643, May 1, 2014.
  1. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    About to put an explorer rear end with disk brakes on my 1971 Maverick and wondering which front to rear brake line to use? Here are the ones listed in the catalog. I assume beings it is no longer drums I would use the LIN7501S or LIN7601S but wonder whats the difference or would I still use LIN7101S? Thanks
    [FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold]FRONT TO REAR[/FONT][/FONT][FONT=TimesNewRoman,Bold]
    [/FONT]- Goes from proportioning valve along the length of vehicle to
    rear flex hose.
    [FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold]LIN7001……………………………………………….59.00[/FONT][/FONT][FONT=TimesNewRoman,Bold]
    [FONT=TimesNewRoman,Bold]LIN7001S…( Stainless Steel )………………………..69.00[/FONT]
    [/FONT]71-77 Maverick & Comet w/ Drum Brakes
    [FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold]LIN7101……………………………………………….59.00[/FONT][/FONT][FONT=TimesNewRoman,Bold]
    [FONT=TimesNewRoman,Bold]LIN7101S….( Stainless Steel )……………………….69.00[/FONT]
    [/FONT]1975 Maverick & Comet
    [FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold]LIN7501……………………………………………….59.00[/FONT][/FONT][FONT=TimesNewRoman,Bold]
    [FONT=TimesNewRoman,Bold]LIN7501S….( Stainless Steel )……………………….69.00[/FONT]
    [/FONT]76-77 Maverick & Comet
    [FONT=TimesNewRoman,Bold][FONT=TimesNewRoman,Bold]LIN7601……………………………………………….59.00[/FONT][/FONT][FONT=TimesNewRoman,Bold]​
    [FONT=TimesNewRoman,Bold]LIN7601S….( Stainless Steel )……………………….69.00[/FONT]
    [/FONT]
  2. 71gold
    are you running the calipers...one front and one back or both on the same side. if you run them both to the back the stock E-brake cable can work...:yup:
  3. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    Both rear e brakes but wondering difference in brake line going front to rear. Is it different size when disk instead of drum as they list several different ones
  4. rthomas771
    I used my lines with fittings from the Crown Vic lines. Had to re-flare my hard lines and use the Crown Vic flex lines that connected to the calipers
  5. Paul Masson
    1971 Grabber
    You will have to pick the line that corresponds to the proportioning valve threads you are using. Then you can just purchase the correct rear hose to match the new line. For the length of them, the two short rear hard lines would be easy enough to make from scratch using the Crown Vic fittings on the outer ends like Jeff said. I suspect the size of ALL the brake lines is the same 3/16".
