front suspension
Discussion in 'Technical' started by hotrod-daddy, Mar 21, 2008.
  1. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Does anyone know if the front coil spring supension from a fox bodied Mustang will fit under a Maverick?(y)
  2. blugene
    Is this the one with the struts? Like a camaro? :hmmm:
  3. newtoford
    newtoford Member
    New Castle Delaware
    fox bodies have that drop out K-member. its alot diffrent then mavericks
  4. hotrod-daddy
    hotrod-daddy Member
    suspension
    Yes it does.....but I plan to change the spindle assembly with a disc brake set-up(y)
  5. hotrod-daddy
    hotrod-daddy Member
    suspension
    What I'm getting at is.....The fox bodied frame and our cars frame the same
    distance between frame rails?:thumbs2:
  6. Jamie Miles
    While I don't have any exact measurements, I can say that the distance between the frame rails on my 1980 Mercury Capri RS is definitely further apart then the Maverick. Below is a picture of the engine bay of the Capri, I don't have any decent pics of the Maverick engine bay I don't think.
    If you do figure out some way to make it work, buddy, I'm all ears!
  7. Dave B
  8. hotrod-daddy
    hotrod-daddy Member
    Thanks for the pic Jamie. I'm going to the boneyard this weekend....I'll take my tape measure. I'll let you know what I find out.
  9. hotrod-daddy
    hotrod-daddy Member
    suspension
    Thanks Dave, I'll keep that in mind(y)
  10. okibono
    okibono Member
    cali
    or aje... they make a fox style kit... lotsa info and pics here...
