front suspension
Discussion in 'Parts Interchange' started by dirt racer, Jan 12, 2006.
  1. dirt racer
    dirt racer Member
    southern pines NC
    70 maverick
    Building a dirt car trying to figure out some front suspension delemas, would like to get a 5x5 5/8 stud front rotor on a maverick, the front hubs of a 75 ltd are 5x5 but use different bearing,and the spindle uses different balljoints. I know granada hubs bolt right on, but i dont have any and was wondering if they could be redrilled to 5x5. If you wondering the 9 inch rearend i am planning to use is a floater and has 5x5 bolt pattern and used 5x5 wheels are cheap and easy to find.
  2. dirt racer
    dirt racer Member
    southern pines NC
    70 maverick
    If anyone wants to know. I found a 5x5 granada hub and rotor. The rotor is .810 thick but just might be what im looking for. Thanks to anyone who tried to figure this one out.:woohoo1:
  3. courier11sec
    courier11sec Member
    Tucson, AZ
    I didn't know Granadas ever came in 5x5. I just caught this thread and was thinking maybe a Mark hub would work. Glad you found something.
  4. Mavaholic
    Im curious as to what the rotor actually came from. Granadas didnt have 5x5 from the factory.
  5. dirt racer
    dirt racer Member
    southern pines NC
    70 maverick
    Its a racing rotor (looks factory cast) that racers mount on pinto spindles used on dirt modifieds. I got a set for my camaro last year from speedway motors in nebraska (camaros are 5x4 3/4 stock) but they show no listing for ford. I assume somebody is buying undrilled rotors and drilling them, The ones i got for my camaro only have one set of holes. I found a company in arizona that sells them for a ford. Most of the modifieds around here with pinto spindles run the granada stock rotor and run an aluminum spacer/adapter to use 5x5 wheels.
