Front & Rear Tire Size for 15x7
Discussion in 'Technical' started by Wright712, Jul 25, 2009.
  1. Wright712
    Wright712 Member
    I am buying 4 15x7 wheels with 4" backspace. I have a stock suspension, but plan to drop a V8 in the front. Should lower a little. Also may adjust the rear after deciding on my tires.
    Two set-up questions:
    1) Best daily driver tire which can be rotated and get good, even tire wear. Been thinking 215/60/15
    2) Best tires for a rake look? Been thinking 235/60/15 and 205/60/15. Can I get any more meat under the rear?
    Thanks guys! :bowdown:
    Jason
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    it is hard to fit any wider because you have 4 inch back spacing if you had 3 1/2 then you could have went a lot wider
  3. Joe Dirt
    on a 7" wheel Id probly go a 215/70/15 and a 225/70/15
    or for more of a rake a 205/70/15 and a 235/70/15
  4. 1973Maverick357
    Cookeville TN
    No! I have 215/70/15 it rubs like crazy in the front!
  5. Joe Dirt
    Well,Excuse me..
  6. mean_maverick
    what's your backspacing? ive run 215's in the front before w/o any issues....
  7. 1973Maverick357
    Cookeville TN
    Lol i was just kidding joe but idk what the back spacing is they are 15x7 cragar ss
  8. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I have 235/60/15's on the front of my car on 15x7's and it's lowered alot more than I like and I don't have any rubbing problems... thing is I can't remember how much backspacing I'm using... when I ordered the rims I remember asking for centerline so for a 7" wide rim I should have 3.5" of bs but I'm not sure... haven't bothered to pull one off and take a measurement of the bs... I plan on eventually running 235/60-15's on 15x7's w/ 3.5" bs all the way around.
  9. Wright712
    Wright712 Member
    Thanks for the responses. :)
  10. baddad457
    :hmmm::hmmm:
  11. baddad457
    235/60 front, 245/60 rear. The rear can go much wider if you're willing to do a little modification like helper springs, wider wheels or rolling the fender lips.
  12. Joe Dirt
    those look more like 8's or 10's
