Front Brakes Help
Discussion in 'General Maverick/Comet' started by Scoopy, Jan 12, 2004.
  1. Scoopy
    Scoopy Member
    Mexico City
    1972 Maverick Grabber
    Hi guys,
    Yesterday I started changing the front brake pads, but when I took the caliper down a small metal clip came loose.
    I just can’t find were does it go, can someone give me a hand or send a picture PLEASE
    Thanks
    Scoopy
  2. Earl Branham
    Lugoff, SC
    Scoopy; sounds like the anti-rattle clip. There is one each, on the inside pad, down at the bottom tab. If you remove the other wheel, look at the inside pad of the caliper, it is there. If you don't use it, the pads will rattle like crazy, and if the rotor is out of round a bit, it gets worse. Hope this helps.
    Earl
  3. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    hate to sound stuck up as i am ase certified in brakes:D but it would help to see what this peice is if its not rattle clip
  4. Scoopy
    Scoopy Member
    Mexico City
    It is the anti-rattle clip, but just cant find were does it go, I took apart both front brakes and the clip just jumped off.
    I know It was very dumb of me taking apart the other brake without looking were the clip goes.
    A picture would help me a lot, I sat down for 2 hours and just couldn’t find were the #$%&$# clip goes.
    Thanks guys.
  5. 71gold
    :rolleyes: it clips on one end of the pad. it will only go on one way.
