Fox Body Drive shaft
Discussion in 'General Maverick/Comet' started by Eddie Maverick, Mar 9, 2008.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    I read here a while back that you could swap a fox body diveshaft into the Mav (2 door) only needing to swap the slip spline from the mav's driveshaft onto the fox's. Well I picked one up (fox driveshaft) and have a problem/question.
    The U joint on the fox drive shaft is longer/bigger that the mav's u joints. How do you get around this?
    The problem I'm having is that the fox u joint won't seat into the u joint carrier on the 8". It had locator tbas and the fox u joints stick out past the tabs. I had planned on buying new U joints anyway, but obviously the fox ones wont fit. And It looks like the mav ones would sit too far into the yoke on the fox driveshaft.
    What to do, what to do????
    Thanks guys
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    DUCK TAPE:clap::D
  3. newtoford
    newtoford Member
    New Castle Delaware
    sorry i cant help you but whats the advantage to fox drive shafts? are they lighter or something?
  4. eddie1975
    Martinsburg, WV
    sold
    aluminum i believe
    Limeade is the man to talk to:thumbs2:
  5. newtoford
    newtoford Member
    New Castle Delaware
    cool, i remember someone here pulled an aluminum shaft out of some SUV or truck any only had to pay to have a few inches knocked off it and it bolted right up
  6. 74CometGT351W
    74CometGT351W Dano
    Marion, NC
    1974 Comet Gt 351W T5 8.8 .520/.545 hydraulic cam 1 5/8 headers
    mine seems to be pretty heavy duty feeling. I don't know what it's made of, it's pretty heavy, I think it's out of an '89 GT. Seems to be a bigger diameter than a stock maverick one. About the u-joints I'm not sure. Mine's mustang from tranny back:huh:
  7. Shinysideup
    Shinysideup Chillin the most
    town
    car
    The fox driveshafts are steel. You can use the stock mustang one or the FMS aluminum for the same DIRECT replacement of your maverick one.
    The solution to the u-joint is get a 3 1/2" to 3 1/4" u joint. I have done this already.
  8. Shinysideup
    town
    car
  9. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Can you clarify what you mean with those measurements. Do you mean 3 1/2" x 3 1/4" u joint?
    Or do you mean I need a 3 1/2" to 3 1/4" like as in a scale of sizes?
    Thanks
  10. yellow75
    Tillamook Oregon
    Eddie what he is saying is that they make a u joint that fits your application with a span one way of 3 1/2 to fit the Mustang joint side and a span of 3 1/4 to match the Maverick yoke.
  11. Shinysideup
    town
    car
    Exactly. I bought a good quality spicer brand. The autozone fools wont know wtf, so go to driveshaft shop or maybe napa. Dont bother telling them "what vehicle", say I want a 3 1/2" by 3 1/4" HD joint.
    Dont forget to grease after install.
  12. eddie1975
    Martinsburg, WV
    sold
    nice car there shiny:clap:
  13. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    NICE!!!!
    Thats what I needed to know
    I'll check napa tomorrow to see if they have it.
    Thanks all
    Thanks Shiny
  14. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    THE BRAND PRECESION PART NUMBER IS 331 OR 347. I can't remember other than it was a stroker kit number....
  15. mustangturbo50
    mustangturbo50 Member
    bettendorf, ia
    driveshaft
    ok i got a whole 5 speed tremec swap and im putting it in my car. will my factory driveshaft work or will it need to be cut? if i have to cut it ill just go to aluminum. any ideas from anyone who has done the 5 speed swap?
