hey fellows i will be using the c4 trans thats in my car but i have a 302 5.0l 347 stroker late model engine and would like to know which flywheel to use and starter
Measure the depth of your flywheel. If it is 5 7/8" deep, use the 157 tooth flywheel If it is 6 1/4" deep , use the 164 tooth flywheel. When you know what flywheel you have you can order your torque converter. There are two bolt patterns - One for the large flywheel and one for the small one.
