floorpan rust
Discussion in 'Cosmetic' started by 71mavkidd, Jun 11, 2008.
  1. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    i have some places where my floor pans are pretty rusted out. this is my first project car and i assume it should be cut out and new welded in. i have now idea where to start or really what to do or use to do it at all. even the simplest of tips and pieces advice are needed as well as appreciated.:bowdown:
  2. 71gold
    Hi, :Welcome:
    could you post some pics. of what needs to be repaired?
    most times you will have to cut a patch panel from a donor car.
    ...Frank...:Handshake
  3. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    i cant figure out how to make my pics small enough files to upload :mad:
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
  5. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    thanks for the help got the pics up
  6. 71gold
  7. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    just checked them and yes they do leak:(
  8. 71gold
    my suggestion would be...repair the leak in the cowl first...:Handshake
    if you do a search on...cowl repair... you should find a few diff. ways to do this. pick the one that would be in your best interest.:thumbs2:
    good luck...
  9. Jean Doll
    Palmerton, PA
    What Frank said.:yup: Nine times out of ten the leading cause of floor rust is water leaking in through rusted out cowls. That problem need to addressed first before taking on the floors. As for the floors, they don't look too bad, but a lot can be hiding under those rust scabs. If you have a ballpeen or autobody pick hammer handy, try tapping firmly on the rusty areas to see how much of it crumbles away and how much remains solid. That will give you an idea of how extensive the rust really is.
  10. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    i checked and nothing really crumbled. i think it is solidexcept for a few pea sized holes
  11. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    i read somewhere about just plugging up the cowls but i dont know exactly how that would be done and cant find any articles on it :(
  12. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    The best rust repair is always to replace the rusted metal with new. However, if you do the steps in the thread Frank posted, you should come out a with solid floor to give you service for a time.
  13. Acornridgeman
    Wisconsin
    As soon as you hit those pea sized holes with an angle grinder / wire brush - they will be big enough to stick your hand through. I did a thread on floor repair awhile back. Easy enough to weld in new pans fabricated from Mustang pans.
    :thumbs2:
  14. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    thanks. i am planning to cut out and weld new in but to fix the leak can i just plug up the cowls? i cant find any threads on that i found some on fixing and read they can just be plugged. is that an acceptable fix?
  15. mavgrab302
    I think you should remove cowl and repair all the rust. That being said some of us are working stiffs with a budget. google cameo car club they are in Deland Fl. on there site is a how to on welding in the vents on the out side. looks good but it changes the way our cars look and you wont have fresh air vents any more.
