Floor shifter
Discussion in 'Technical' started by Mav Rick, Mar 5, 2005.
  1. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Hey all. My 71 grabber was orig. a column shifter, but was changed over to a floor shifter with a B&M (shift cable). I was going to change it to a floor shifter with an original shifter off a 74 (linkage). Should this be a problem from going from 74 to 71? I wasnt sure if the had floor shifters on the 71's.
    Any and all help will be greatly appriciated!!
    THANKS!
  2. Mavaholic
    It will bolt in with no problems. You will have to drop the valve body in the trans and flip the shift arm 180 degrees to use the mechanical linkage.
  3. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    That sounds difficult... are there pics out there of this?
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i made a adaptor for mine did not have to drop the pan, this just slid the adapter over the shaft, and i hooked my linkage to it. works great.
