floor shifter conversion
Discussion in 'General Maverick/Comet' started by Hon450, Jan 9, 2011.
  1. Hon450
    Hon450 Member
    West Des Moines Iowa
    I need a little help. I have a automatic column shifter that i would like to convert to a automatic floor shifter. I was wondering what would all have to be changed out to do this. Curious to no if anyone has measurements for the placement of the shifter.
    All input would be great thanks in advance
  2. injectedmav
    injectedmav Member
    Georgia
    a donor car would be best but if you get the parts from a salvage yard you need the linkage rods, floor shifter, shifter mounting hump( bolted into the floor under the carpet on floor shift cars), the collar from the the steering column (if you don't want to make a cover for the indicator), wiring for the floor indicator light, and anything else you can grab. my factory floor shift cars had a rod that went from the trans to the column to lock the shifter when the key is in the off position.
