Float Adjustment
Discussion in 'Technical' started by yellow 77, Feb 28, 2007.
  1. yellow 77
    yellow 77 New Member
    bellingham, washington
    maverick
    I have a 6 cyl, 2.5 engine and need to adjust the float on my carb...i am new to mechanics but want to fix my 77 mav by myself. can i use my chiltons manual to fix this problem?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Not sure which Chilton manual you have. But if your taking the carb apart to adjust the float you will likely damage the gasket in the process. I would go ahead and pick up a rebuild kit and rebuild the carb. The kit will come with detailed instructions.
  3. Craig Selvey
    The carb float is adjusted with the carb off the car and disassembled....so might as well rebuild it.
