Flexplate fun!
Discussion in 'Technical' started by CACollo, Nov 18, 2002.
  1. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    Hi,
    Well i'm about to get started on installing my new torque converter (TCI 2400stall part #451100), and of course the bolts don't line up with my flexplatel! The motor i have is a 1980 302, and my transmission is a '78 C4. I have a smaller flexplate that i believe came off of a early 70's 302 that the torque converter bolts right into. I realize this will mean a smaller bellhousing, but other than that, any problems? I believe the balance factor is the same between the '80 302 and the mid-70's 302, it's just a difference in flexplate size/number of teeth, right?
    Thanks!
  2. mavman
    mavman Member
    Arkansas
    nope, all you'll need is a matching "small" bellhousing. Easy swap. Good luck!
