extremely high pitch squeal from the pass. front?
Discussion in 'Technical' started by xpsnake, Oct 20, 2005.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Since I did my brake/spindle swap, I've noticed an extremely high pitched (I'm ultrahighfrequency sensitive) noise coming from the passenger front wheel. If I turn the steering a little to the left, it goes away, if I tap the brakes, it goes away. I've taken the pads off and coated them in anti-squeal, that fixed my low speed noises but this is something different. Does anyone think this could be my (new) wheel bearings?
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Could be, or a sticking caliper. I am guessing that you switched to discs. Does it stop when you hit the brakes?
    If not a caliper pull the wheels and check the bearings for heat after parking it.
    Seth
  3. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    I know its a dumb question but ...you did pack the bearings with grease right???
    good luck...Jim
  4. xpsnake
    xpsnake Bruce
    Packed 'em REALLY good with RED wheel bearing grease, the good stuff.
  5. Mavaholic
    I'll bet its the pads still. Like Seth said, does it go away when you hit the brakes?
  6. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    move pads to other side and see if it still does it
  7. 71gold
    Seth[/QUOTE] :hmmm: :huh: :bouncy:
  8. 71gold
    you can also "pack" the bearings "too" tight. this makes the rollers in the bearing "slide" and not roll. are these new bearings and how tight did you tighten the nut? :huh:
    did you get any "grease" on the pads? i take 180 grit sand paper and a flat surface and scuff the pad face before i install them. ...frank...:bouncy:
  9. 74MAV
    74MAV Gearhead
    St. Louis MO
    74 Maverick
    If the anti-rattle clip is not installed correctly it will make that kinda noise.
  10. Earl Branham
    Lugoff, SC
    Didn't run over any cats, did you??????:rofl2:
  11. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    :hmmm: :huh: :bouncy:[/QUOTE]
    I'm getting to the point Frank! Excessive heat on that side vs.
    the other side is what I meant to say. Maybe he has some
    mismatched parts or bad bearings or they are too tight.
  12. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Check the dust shield behind the rotor.
  13. xpsnake
    xpsnake Bruce
    Lol! C'mon guys, read carefully! Thanks for the suggestions so far.
  14. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Yes, I think it has something to do with your 'new' wheel bearings (since it 'goes away' when you turn the wheel).
    :2cents:
    Please keep us updated so we can refer back to this thread when someone else has a similar problem.
