Exhaust Manifold questions.
Discussion in 'Technical' started by Dean Deeter, Aug 14, 2013.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Have a 200 74 Maverick redoing for my wife. There are 2 tubes coming off the exhaust manifold. One is going to the choke, this tube has two holes in it. What are my opitions. Is there any of these available? What about electric choke? Do the holes make a difference?
    What is the other tube for, I believe this is a heat tube as well.
  2. simple man
    simple man Member
    Bunnell,Florida
    One goes to the choke and the other draws fresh air from the air filter. Both can be replaced with ¼" copper tubing. This can be purchased at any hardware store. Make sure to be careful with the asbestos wrapping and reuse it on the new pipes. It is an insulator for proper heat transfer. :)
  3. Dean Deeter
    Dean Deeter Member
    The one that does not go to the choke is in good condition it looks like it has a rubber line that attaches to it. Is that correct? You say it goes to the Air Filter?
  4. simple man
    simple man Member
    Bunnell,Florida
    Yes. Lift off your air filter and there should be a little nipple on the bottom that the hose goes on. :)
  5. Dean Deeter
    Dean Deeter Member
    What is the purpose of the fresh air? Is it needed? Can I do away with it?
  6. simple man
    simple man Member
    Bunnell,Florida
    It was done because the earlier cars just took the air for the choke right from where this tube is. Ford found out that dirt would eventually plug the air off and the choke wouldn't work correctly. I also have a 74 and I do not have the fresh air tube on mine. I don't drive in the rain or on dusty roads so I'm not at all worried about it! If you drive your car in reasonably clean conditions, you will have no problem. :)
  7. Dean Deeter
    Dean Deeter Member
    Can I use this port for the choke and plug the line that was used for the choke??
  8. simple man
    simple man Member
    Bunnell,Florida
    You can use either port, but do not plug the other one! All those two ports are is a cast in channel that goes through the manifold. It heats air and the tube that goes to the choke has a vacuum draw when the engine is running. This tube will get very hot so that is why it's covered with an asbestos wrap and connects to the choke with a flare fitting. Do not try to use any kind of hose on this! It will burn up! I like copper tubing because it bends easily and doesn't rust! :)
    littlekentucky likes this.
  9. Dean Deeter
    Dean Deeter Member
    Just curious?? Why does the one tube get hot and the other does not? Is it because of the vacuum draw on the carb.
  10. simple man
    simple man Member
    Bunnell,Florida
    The one tube is inlet air ( cool ), the other is heated air ( very hot ).
    You'll notice that the inlet tube has the hose very far away from the manifold, so it won't burn! :)
  11. Dean Deeter
    Dean Deeter Member
    Thanks for the info..
  12. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I'm bring this post forward as it was useful in answering my recent post on heat tubes. Thanks to Steve and Crazy Comet.
    MD
