Engines?
Discussion in 'Parts Interchange' started by Wa. MavMan, Feb 16, 2005.
  1. Wa. MavMan
    Wa. MavMan Member
    I'm thinking of swapping out the 250 that is currently in my Maverick and replacing it with a 302. Does anyone have a round about estimate of how much this might cost I've heard it said that I may have to do some modifications in order for the 302 to fit. What will I have to do?
  2. Bradley M.
    Bradley M. Member
    Hawaii
    1970 Ford Maverick
    Change your frame mounts & motor mounts only. trans crossmember & driveshaft can still be used,but would suggest upgrading to a thicker shaft for increase in horsepower.
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Add the engine crossmember that goes under the oil pan for stability.
    Seth
  4. Jamie Miles
  5. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
  6. HeLMeT 76x2
    HeLMeT 76x2 Two 76 Fords...!!!
    Vancouver, wa
    1 1976 ford 4-door maverick. 1 1976 ford econoline 100.
    so far, i've had to just get new frame mounts and the "z-bar"... the 250 i-6 tranny stayed in for me... i've just had tons of problems.. now that its been sitting 2 years, i' can't find a single damn bolt to put it back together! DOH
  7. bmcdaniel
    :D Whatever you estimate, double the money and triple the time.
  8. Country Mav
    Evans, Louisiana
    And everyone said....AMEN!! That is so very true!! Preston
  9. stmanser
    Davenport, Iowa
    just take your time.....YOU WILL....i repeat WILL meet some resistance and problems will arise....just take them in stride....i did the 302 swap in my car....i had the engine completely built in the shed and then took the heads off when i put the engine in.....it actually helped a little having the heads off...
    and i dont know if anyone had a problem with headers fitting...but to be on the safe side....i out the headers in the hole first and then dropped the block down....that way as to not scratch the engine and the headers too badly....
    but i had it all done in 4-5 days.... working 8 m to 8 pm every day... with a lot of frustration breaks... and i did not clean up the engine bay at all... should have taken the time...but oh well...
    good luck
  10. maverick75
    if i were u i would try to get a 302 before 74 they have about 290 horses after 74 they dropp to about 134 but i'm not 100% sure about that . Mine was converted from a 75 302 to a 67 289 w/about 100 horses more than the 302. But any 302 is better than a L6.
  11. bartikus
    bartikus Member
    salt lake city, ut
    i think your best bet would be to find an old 302 maverick that is only good for a parts car. that way you get all the stuff you need.
