Engine/Tranny question...
Discussion in 'General Maverick/Comet' started by KISSarmy, Apr 1, 2011.
  1. KISSarmy
    KISSarmy Member
    California
    Hi.
    I've got a '71 Maverick with a 6cyl.
    I want to get a 289 or 302. Which Tranny should I get, if I have to upgrade or switch.
    Thanks!
  2. rthomas771
    If you already have a manual transmission then you can use it. You can use your automatic transmission IF you drive like a grandpa. If you're going to act like Steve McQueen behind the wheel you will want a v8 automatic transmission.
  3. KISSarmy
    KISSarmy Member
    California
    No racing. Highway speed and just country driving, Saturday nights going out for Burgers. Easy stuff. It'll end up just being a good lookin' car when I'm done.
    Can the stock Tranny stand up to that? Or, is it just better to get a V8 Tranny.
  4. MaverickLVR
    MaverickLVR takes longer then you think...
    Grand Rapids, Michigan
    1976 Maverick Stallion, 1967 Olds Delmont convertible, 1999 Harley FatBoy
    the C4 is bullet proof.
  5. PaulS
    If the six you have is a 250 then use the same transmission/bellhousing with the V8 flexplate. Otherwise I would recommend you get a C4 to match your V8.
