Engine Rebuild Need Specs for 250
Discussion in 'Technical' started by vvr210, Mar 15, 2012.
  1. vvr210
    vvr210 Member
    Vista,CA
    Hi I'm rebuilding my 250 engine but I'm limited on specs..those anyone know where I can get general specs,torque tightening specs,crank specs,valve specs,piston ring and cylinder specs and camshaft specs...I have some of tehm already but I would like to re assure myself thanks a lot
  2. simple man
    simple man Member
    Bunnell,Florida
    I'd pick up a manual for your car. They are around $12 at most parts stores. :)
  3. vvr210
    vvr210 Member
    Vista,CA
    I have my chiltons manual but its still limited on certain specs..and it doesnt provide any cam specs
  4. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
  5. vvr210
    vvr210 Member
    Vista,CA
    Did you rebuild a 250 as well?
  6. sportyfamilycar
    KY
    (2) 77' Mavericks
    I went through mine, I didn't machine anything or overhaul too crazy though. I replaced with stock size piston rings, new valves/lifters/ and gaskets.
  7. vvr210
    vvr210 Member
    Vista,CA
    K..i wasnt able to find a haynes manual on a small block 250 u know where i might be able to find one?or maybe some online references
  8. sportyfamilycar
    KY
    (2) 77' Mavericks
    buddy I'm not sure if theres much if any books/guides for the ford small block six cylinder, but there might be. I used a Haynes small block windsor v8 book as a quick reference for some things.
    [ame="http://www.amazon.com/How-Rebuild-Small-Block-Ford-Engines/dp/0912656891/ref=sr_1_1?s=books&ie=UTF8&qid=1331865459&sr=1-1"]Amazon.com: How to Rebuild Small-Block Ford Engines (9780912656892): Tom Monroe: Books[/ame]
    Also alot of specs can be found on the classicinlines link I posted and fordsix.com and the fordsix forum. Someone there may have a complete spec sheet.
    good luck with the build (y)
  9. vvr210
    vvr210 Member
    Vista,CA
    I printed out the specs and I'm gonna compare them with what I have..very important information there..thanks a lot ill be posting pics of my progress pretty soon :thumbs2:
  10. simple man
    simple man Member
    Bunnell,Florida
    I just was looking at the Classic Inline's specs and they list a torque value for the intake? :hmmm:
  11. sportyfamilycar
    KY
    (2) 77' Mavericks
    Might be for the head they sale, but idk.
  12. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Maybe those were for either the OZ head or the aluminum head?
  13. vvr210
    vvr210 Member
    Vista,CA
    those intake need a torque value spec?
  14. simple man
    simple man Member
    Bunnell,Florida
    Those two heads that Gene mentioned do have a removable intake manifold. I thought those were specs for a stock 250, but they may have just included that as I would imagine the rest of the specs wouldn't change. :)
  15. vvr210
    vvr210 Member
    Vista,CA
    Oh ok so since i have a 250 straight 6 those specs wouldnt apply to me correct?
