engine nocking noise
Discussion in 'Other Automotive Tech & Talk' started by x72COMETx, Sep 6, 2012.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    i took the car for a drive and it has a 250 inline 6 and the engine strted knocking i think its a bad valve but all of a sudden the exhaust got lower and louder just posting for some opinions.:hmmm:
  2. Mavman72
    Check and see if you have an exhaust leak...Check manifold...Pipe flange at manifold...ETC... Exhaust leaks can make odd sounds sometimes...Good luck!!!
  3. x72COMETx
    x72COMETx Member
    Vallejo CA
    oh it does have an exhaust leak i need a different exhasut flange gasket
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    forget that 250 six i got a 302 just sitting their waiting to be built
  5. 71gold
    sounds like you also have a 6 cyl. sitting there waiting to be built...:yup:
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    this six is just rebuilt
  7. Freelance Fury
    Freelance Fury Member
    Memphis, TN
    1971 Ford Maverick, inline 6
    Can you tell if the knock is from the upper or lower end? That may help you narrow down whats up. How many miles are on it? Could be so, so many things.
