Engine mount bolts backing out
Discussion in 'General Maverick/Comet' started by GreyGhost74, Sep 27, 2014.
  1. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    So while I was putting my shocks in I noticed one of my engine mount bolts that goes into the block had backed out about 3/4 of the way. So I went to check the other bolt. Gone! Tightened the one, checked the bolts on the other side. Here's my problem. The bolt hole with the missing bolt doesn't line up now. Its off by like 1/8" so I can't get the bolt in. Any way to fix that without having to mess with a lift?
  2. Moneymaker 1
    Panama City Florida
    A pry bar and slight pressure.
  3. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Thanks I'll give that a shot. Can I use anything on those to keep them from backing out again so easy, like locktite ?
  4. Moneymaker 1
    Panama City Florida
    I have lock washers on mine.
  5. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    OK. I'll give that a try..
  6. Bryant
    loctite will work. the original bolts are crimp type design. they have a triangle like shape vs being perfectly round. so if using normal type bolts, you definitely want to use loctite on the threads.
  7. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    Thanks they're not original. Most of the bolts on the car aren't lol
  8. mav1970
    Definitely lock washers :thumbs2:
    GreyGhost74 likes this.
  9. Melvis
    Melvis Member
    Milford, IL
    73 Chevy BelAir
    Much better than lock washers, nord lock washers. Fastenall has them. Will not back out
  10. Acornridgeman
    Wisconsin
    Blue thread locker and lock washers on mine. There not going anywhere .............. :evilsmile:
    GreyGhost74 and Dave B like this.
  11. 71gold
    loosen the one you tightened first...
  12. CaptainComet
    • Like Frank said, loosen the bolts that are there first. If a pry bar does not work, use a floor jack under the oil pan. Place a wide chunk of 2x4 or plywood between the jack and the pan to spread out the load and not dent the pan.
