engine is in
Discussion in 'Technical' started by Zooomzoomguy, Sep 9, 2006.
  1. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    engine is in (pics)
    well as of one hour ago i got my engine into the car, sort of my victory post, tomorow will be installing headers and few other things, now i got a quick question, what do you guys use to ran your trans lines to the cooler? just rubber hoses or do you use something else?
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    looks sweet(y) , yeah i like to hear the answer , thats one of things i still need to do to mine:rolleyes:
    eddie
  3. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    Very nice (y)
  4. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Stay away from the rubber lines. You can get 3/8 brake line and bend it to fit the car. Use unions to add more line till you get to the rad. Then cut the line and flair the end and screw it into the rad. No trouble there, trust me the rubber line WILL fail at the least oprotune moment.
  5. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    Yeah. I agree. I bent my own lines and I was much happier with the result. It helps if you have the old ones to go by though.
  6. blugene
    Although I do agree with fordmaster there is a rubber trans hose available but you don't want to use it in long sections... it is sold for adding coolers and will hold up to most street uses. If you come accross this hose think only of using it in short sections with good barbing...
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I use rubber.
    Get fuel line.
    It is designed for use with gasoline and is tougher.
    I agree that steel is optimum, but it is not always 'in the cards'.
    Most car makers use sections of rubber in the lines somewhere, so it's not taboo.
    Dave
  8. ModMav71
    ModMav71 Member
    Sebring, FL
    For coolers I've always used rubber lines. I've never had one fail. I probably wouldnt use them for anything longer than a foot or so. But for coolers they work fine, that's why the companies that make coolers include them in their kits or at least recommend using them.
  9. Dave B
    Motor looks awesome!! as for lines. I like steel, I bought a tubing bender, makes it easy, so there is no reason for me to use rubber.
  10. eddie1975
    Martinsburg, WV
    sold
    i guess flexiable braided stainless steel lines are ok right?
  11. maverick75
    Engine looks sweet(y)...but you gotta clean up that engine bay:D
  12. Jamie Miles
    Alto, GA
    I've had a few
    Yep, I've got over 14,000 miles on the aftermarket trans cooler with rubber lines on my '72.
  13. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    if you still have some of the hard line left....I would use the hard line (from tranny) until I cleared all the heat sources, then flare the hard line and run rubber (easier to run) up to the cooler.
  14. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    i think i'm going to just bend the 3/8 brake line to fit, it would look better then alot of rubber line going all over the place, could i use the same brake line for fuel line in some places too correct?
