engine id tag help
Discussion in 'Parts Interchange' started by bob1963, Jan 25, 2013.
  1. bob1963
    bob1963 Member
    Highland,Illinois
    I thought this would be the best section of the forum to ask.
    I have a 1974 302 Maverick engine in a 1963 Falcon ,the engine does not have a tag on it but I have the stamped numbers on the side of the block..I would like to get a replacement ID tag for the engine.I know I can have the tag made at Marty's auto works, but I need some help understanding how to read the tags.I would really appreciate if some one who knows and understands these tag numbers, can lead me in the correct direction on how the numbers on the tag of my engine needs to be stamped. :)
  2. Krazy Comet
    I have info on tags through 1969 but nothing in the '70s... Tags were updated by date and level change of the engine, meaning if there were a change that required a different component(say dipstick & tube), the tag info was revised... Looking at the casting date would give you a idea of when the engine is built, actual date should be stamped into the block... At that point it'd probably be best to look at another '74 tag and duplicate the remaining info...
  3. bob1963
    bob1963 Member
    Highland,Illinois
    the casting # on the block is D4DE - 6015 - 8A and then it looks like it may have SES
    If I new what a 1974 302 tag looked like I think I woudl do what you said and have a tag duplicated with may block casting numbers on it. Do you think that would close enough ?
  4. rthomas771
    Before 2/1/73 Ford used a metal tag...After 2/1/73 they went to a label (decal)
  5. bob1963
    bob1963 Member
    Highland,Illinois
    So Jeff what your saying is that year engine will not have a tag on the intake manifold any way correct ?
  6. rthomas771
    It will be a decal on the valve cover
  7. bob1963
    bob1963 Member
    Highland,Illinois
    ok Thank You
  8. mercgt73
    The sticker is on the passenger valve cover, facing forward. You can see it hiding behind the dipstick.
  9. bob1963
    bob1963 Member
    Highland,Illinois
    Thanks but I never did have the original valve covers so I won't be able to find the stcker any way.
  10. Krazy Comet
    No doubt needs to find better cover, already has three holes shot into it... :biglaugh:
