engine ID help
Discussion in 'Technical' started by Blown74, May 22, 2012.
  1. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    Bought a motor recently. Has the following numbers on the block, anyone have an idea of what this motor is ?
    28
    E68E
    BA
    Thanks!
  2. Joe Dirt
    Its a 1986 model
  3. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
  4. cody674
    cody674 Member
    1972 Ford Maverick
    and it came from a truck
  5. Blown74
    Blown74 Member
    Va
    engine ID
    So,, no way to tell if its a roller motor? I mean without tearing it down. Could it maybe be an Explorer motor?
  6. Joe Dirt
    Its doubtfull its a roller but should have the provisions for the lifter "spider"
  7. mercgt73
    Would the distributor gear tell you? Might be the easiest thing to pull.
  8. Dave B
  9. baddad457
    You've misread the "8" in E68E, it's an "S". All that aside, it's a roller block, as to whether it's got a roller cam, remove one valve cover, one rocker arm and one pushrod. Roller 5.0 pushrods are 6.25" long. As to what vehicle it came from, (unless you pulled it yourself) this can be narrowed down by Id'ing the rest of the parts there.
  10. Blown74
    Blown74 Member
    Va
    Thanks all
    It was sold as a roller motor. It has trick flow heads, Harland sharp roller rockers, canton rear sump pan, EB airgap intake, AED 750 dbl pumper, steel crank. I heard it run and saw some 11.00 time slips while it was in an 86 fox body mustang.
    I am probably reading the 8 vs S wrong, I'll double check.
  11. baddad457
    You definately are misreading it. There were no E68E blocks, lots of E6SE's out there. Other roller blocks I've seen are E7TE, F1SE. If it's got a main girdle, you'll need to choose your rear sump pan wisely, the stock pans(front sump) won't clear a main girdle's rear main bolts
  12. Joe Dirt
    Then it could have anything in it so the only way to know is to pull the intake
  13. cody674
    cody674 Member
    1972 Ford Maverick
    i didnt think that was right so i went by the e which should have been the s
  14. baddad457
    All that needs to be pulled is one pushrod to tell if it's a roller cam or not. Roller rods in a 5.0 are 6.25" long, flat tappet rods are a half inch longer. No need to disturb the intake.
