engine compartment?
Discussion in 'Technical' started by Johng1970, Mar 31, 2013.
  1. Johng1970
    Johng1970 Member
    Freeport, PA
    I found a large spring about 6 1/2" long x 1 1/4" round and I'm not sure where it goes. I think it might be for the transmission which was a three speed manual on the tree, I changed to the floor. Would anyone know where this spring would go.
    Thanksd
    John
  2. Mavman72
    Probably the assist spring for the clutch linkage. Mounts to a hole on a tab on the firewall and the other end goes to a small hole in the top half of the clutch equalizer bar.
  3. Johng1970
    Johng1970 Member
    Freeport, PA
    Thanks for the info. That has to be where it goes. Would you know where I can get another one? Mine is shot.
    Thanks
    John
  4. Mavman72
    Try N.P.D. or Autokrafters. Its a common part between the old mustangs/mavs. Should be easy to find.
