Eliminating the eccentric bolts on the front end?
Discussion in 'Technical' started by bigal3000, Aug 12, 2004.
  1. bigal3000
    bigal3000 Member
    Vancouver, Washington
    1973 Grabber
  2. Mavaholic
    The way I see it, it takes the now infinite camber adjustment and probably gives you 8 set positions. The proper specs can probably be achieved in 1 of the 8. Personally I think its a waste of money. These are pretty tough front ends and I have never seen the camber adjustment slip. I used to do front end alignments back in the 70's. Setting these fronts is a piece of cake. That would certainly have your front end guy cussing you out.
  3. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    Mine came loose once. I knew something was wrong when my tires howled going down my street at 30 MPH! And my steering wheel was not straight anymore. ;) The lower control arm bushing was shot, and I think that was a major part of the problem.
    Still I don't see the point. Tighten them properly they won't come loose. Spend your dough elsewhere! Or else maybe I'm missing something and you can explain why you were interested?
  4. bigal3000
    bigal3000 Member
    1973 Grabber
    Yes, I found one that gives 8 and one that gives 11.
    Good to hear advice from an actual front end guy.
    Thanks! :)
  5. bigal3000
    bigal3000 Member
    1973 Grabber
    Looking at the way they are designed it just didn't
    seem like it would take much to alter them, like a
    nasty pothole, curb, etc. Something solid as opposed
    to variable always seems like a better approach
    to me. Maybe it's not a concern in this case.
  6. bmcdaniel
    Some of the older, bigger cars used positive stops for caster and camber. If you just use your torque wrench to properly tighten the bolt you won't have any problems.
