Electronic Distributor
Discussion in 'Technical' started by ShuttleMav, Nov 16, 2006.
  1. ShuttleMav
    ShuttleMav Member
    I have an electronic distributor for my 302, what exactly will I need in order for it to work? Just an ignition module? A control box?
  2. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    What kind of dizzy is it? You could get a MSD box, they can be triggered by just about any dizzy made. All you have to do is follow the hookups for the type of dizzy you are using. One thing to remember is that you need a coil that is designed for a CD system when using a MSD or similar ignition box.
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i found that MSD was an EASY install , as long as you can read and see color , its simple
    NOT the cheapest though , actully prolly most $$$$$
  4. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    you will need the wiring harness for the ignition control module to make the retro fit easy.you have 3 types of control modules: duraspark I 1975, ford change the wiring in 1976 control module and added a zener diod but the distributor wiring remained the same.
    in 1977 they went to the duraspark II control module for more power and the big distributor cap for less cross fire. in the chliton's manual will explain in detail the wiring schematic and chages by model year. try to get the motorcraft module if posible' it has more dwell(longer spark) hope this helps a bit. there's always after market ECM's
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Control box and wire harness to match that particular box.
    OR
    Like mentioned, MSD 6 (or better), will work with Duraspark.
    And the stronger coil...
    The large cap can be used on any Ford distributor, even points. You just need both halves of the cap (top and bottom), then swap to HEI style spark plug wires.
    Dave
