Electric water pump drive kits
Discussion in 'Technical' started by Racer_X, Oct 11, 2010.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    Are electric water pump drive kits worth the money? are they that much better?
  2. don graham
    Do you want the electric water pump drive kit or an electric water pump? Moroso has a good water pump drive kit. I have used it before and had good results. I also have used the Meziere electric water pump and am happy with that. Keep in mind that if something happens to either and you're on the road, you're out of luck as most auto parts stores do not carry replacements for these.
  3. Racer_X
    North Carolina
    i saw the morso drive kit in my jegs catalog and was just curious. did u use tha drive kit on a factory water pump?
  4. don graham
    I used it but it was on an aftermarket water pump that I got from Summit. :)
    Actually, I still have it. It never gave me a problem.
  5. Racer_X
    North Carolina
    kool thanx for the info. would it work on a stock pump?
  6. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Yep...works fine on a stock pump.
    Only issue I ever had was I sheared the face of the plastic drive pulley on the electric motor off at a race once...was just a defective part. I got gun shy after that and went with a totally electric WP for the new engine. Never had cooling issues with the drive kit though...
  7. don graham
    When I had mine on the race car I always carried a spare, just in case. The only time iI used it was when a friends wife had one go out on her car. I think there pretty reliable, but something can always happen. Not sure if there's any advantage on a street car though.:)
  8. Racer_X
    North Carolina
    i will try it and see what happens. should be an iteresting experinent :)
