Elec. Water pump ?
Discussion in 'Technical' started by nelson, Feb 1, 2013.
  1. nelson
    nelson Member
    va
    71 maverick grabber
    Ok i have a 351 w in a 71 mav i put a elec water pump on it now i cant put a belt on it because the pump is in the way for the alt...has anyone had this prob ...and how did u lower the alt ....i pray someone has pics please help
    :huh:
  2. rthomas771
    Are you using a low mount alternator?
  3. nelson
    nelson Member
    va
    71 maverick grabber
    no the factory one ....i didnt know they made a low mount one
  4. rthomas771
    Here is my setup on a 289 in my Falcon. You need to make the top bracket and buy the lower bracket.
  5. nelson
    nelson Member
    va
    71 maverick grabber
    thank you so much were can i buy the lower bracket at
  6. rthomas771
  7. don graham
    I use the Moroso kit also but I found mine on ebay. I have a Meziere electric water pump.
  8. 71gold
    with A/C...:yup:
  9. groberts101
    groberts101 Member
    Minneapolis, MN
    there are more than afew brackets out there that will work. Just need to stay away from the water pump mounted styles is all.
    There's also a nice one being made now for electric's.. that has a billet cage style bracket that uses the mini alternator.. but right off the top.. I can't remember who makes it.
  10. John Holden
    John Holden Member
    NJ
    Look at the picture in post #144 in my build thread http://mmb.maverick.to/showthread.php?t=80855&page=15
    I used the stock bracket that mounts to the cylinder head but I flipped it around. I think I had to file one of the holes a little. I made the top bracket from a piece of flat stock. It was pretty easy all in all.
