Egr
Discussion in 'Technical' started by maver!ck, Jul 21, 2005.
  1. maver!ck
    maver!ck The Maverick Guy.
    Colton
    69.5 Mav, 5.0T
    how do u convert a egr engine to non-egr?:hmmm:
  2. Jamie Miles
    Not sure if it's the same on V8's but on straight 6's you have to get a non EGR carb spacer to replace your EGR one.
    I did it on my '74 when I had the engine out: http://5hp.hill.cc/Maverick/page4.htm
    First pic shows it. Just unbolt your carb, unbolt the spacer, bolt your new spacer on and block off the vaccum line that used to go to the EGR valve. I would imagine it's a fairly similar opperation on a 302.
  3. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    You won't pass smog in CA if you do it.
  4. maverick75
    i think it doesn't need smog only 76 and up
  5. stmanser
    Davenport, Iowa
    i had an egr intake....when i had the heads off last....i just got in intake gasket kit....it came with exhaust gasket material to block off the EGR from intake to heads....
  6. Max Power
    St. Paul, MN
    I thought Arnold changed it....
  7. maverick75
    let me check-if he did i'm gonna have to get a fake smog then
  8. maverick75
    i just checked it sais this
    "All 1975 and older vehicles are exempt from smog certification requirements."
    -:bananaman i got lucky:dance:
    http://www.dmv.ca.gov/vr/smogfaq.htm#BM2535
  9. Max Power
    St. Paul, MN
    That was close!
  10. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    It used to be 30 years and older, but that stopped in 2005. Now it's 75 and older cars.
  11. 74GrabberBlue
    74GrabberBlue New Member
    Chicago IL
    1974 Grabber Blue 302 3spd standard
    figures, I move to IL where they still require emissions test on my 74. With my 2bbl I just put a piece of cardboard in place of the gasket between the ERG valve and the EGR spacer plate. I still passed emissions . . .before the hot cam and 4BBL. . Now I'm in a pickle. Does any one have a digital pic of their STOCK 302 with the Vacuum hoses in their original places? I need to undergo a visual inspection and have 2 hoses and a T left over.
  12. Smith
    Smith Member
    Normal, Illinois
    70 170 Mav
    it's just those big metro areas, chicago, e.Stl....there are a few others. emissions testing, special gas, psshhhhht stinkin tree huggin epa.
  13. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    lived in illinois until 6 years ago. did not know they had emissions test.
  14. 74GrabberBlue
    Chicago IL
    Sadly, in the greater Chicago land area 74 is still tested. I moved here 7 years ago from rural NM where I didn't have to test either. Someday they give up. . .maybe.
    Still looking for a picture of vacuum hoses from a stock 74 302.
  15. Smith
    Smith Member
    Normal, Illinois
    70 170 Mav
    i have 77 in the garage, i don't know how similar it is to the 74 but regardless, here are a few, i can get more/better.
