efi eec-v conversion docs.
Discussion in 'Technical' started by bomrat, Oct 10, 2011.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    hi, i am going to document what i did to convert my 74 comet to a 5.0L from a 97 mercury mountaineer. i am using the 5.0L engine, 4r70w, eec-v, wiring harness, and accessories front the moutaineer.
    i started to run through the wiring and here is some of the drawings.
    parts used:
    97 late year 5.0L block (rebuilt)
    Ford Part numbers: F4TE-6250-BA cam shaft
    * Advertised Duration: 256 / 266
    * Duration at .050 in.: 186 / 197
    * Gross valve lift: 0.422 / 0.448
    * Lobe separation: 116°
    trickflow 170 cfm high port heads.
    trickflow 1.6 roller rockers (might change to 1.7 later)
    trickflow push rods. (don't know the length but they are right)
    arp bolts
    the mountaineer intake, maf, etc...
    mountaineer ecu and wiring harness. (no pats on 96 or 97)
    tweecer r/t
    4r70w for the transmission.
  2. Bryant
    are you going to program the computer? i believe that you at least have to disable the theft prevention system. if you are what are you using to program it with?
  3. bomrat
    bomrat Member
    i picked up a tweecer r/t and the 97 doesnt have pats.
  4. 351cMAV
    351cMAV Member
    Canada
    76 Maverick 2dr
    im looking forward to hearing about the process you went through. I bought a wrecked 96 explorer that im going to use the drivetrain from, but want to put a t5 behind it. Is your engien stock ? Any reason you choose tweeter Rt over Quarterhorse?
    im sure i'll have lots of questions for ya:hmmm:
  5. bomrat
    bomrat Member
    engine is rebuilt, trickflow high port heads. roller rockers. later i might shave the heads and raise the compression, and probably upgrade the cam. but for now i want to just get it running. working through the wiring now.
  6. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    I have Alldata and can create PDF files, so if you need any wiring diagrams or pinouts just send me a PM and I'll post what you need.
  7. bomrat
    bomrat Member
    ecu box and wiring.
    well so far, this is what i have done for my ecu. i cut a hole in my cowl and fabricated a water tight box and the mounted it in the firewall. checked hood clearance and it worked great. i am wiring now. i have finished half of the wiring. i still have to remove the rear o2 sensor wiring out of the harness and then run the wires back to the transmission.
  8. Clintd
    Clintd Member
    Parlin NJ
    In order to be OBD-II compliant the OBD port has to be accessible from the drivers seat.
    LOL!
  9. bomrat
    bomrat Member
    OH CRAP thanks for the info.. well i guess ill add it to the list of not being carb / epa compliant as well. :)
  10. mojo
    Is that required/necessary on an old car upgrade/restoration?
  11. bomrat
    bomrat Member
    02 ecu pinouts
    here is the pinouts and locations of the o2 sensors. i will be removing the wiring from the ecu harness for the rear o2's, sense i will not be running rear o2 sensors.
  12. Clintd
    Clintd Member
    Parlin NJ
    It was just a joke.
    One of the rules for a car to be OBDII is for the OBD port to be in reach of the drivers seat.
  13. bomrat
    bomrat Member
    which makes no sence. when its easier to access something like that in a passengers seat...
  14. bomrat
    bomrat Member
    today i cut apart the harness going to the transmission, removed the harness connector, removed the rear O2 sensor wiring, and ran and connected the transmission.
  15. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    Sounds like your in the same boat as me! there was no room for the connector between the tunnel and 4r70w trans. Thats what i'm working on now and the wiring phase of my resto will be done.:thumbs2:
