Drum brlake to disc brake upgrade 71 Comet GT
Discussion in 'Technical' started by 1971 Mercury GT, Dec 22, 2008.
  1. 1971 Mercury GT
    1971 Mercury GT 1971 Mercury Comet
    Rancho Cucamonga, Ca
    1971 Mercury Comet
    Excuse my bad spelling. I own a 71 comet gt and was thinking of swapping out the drums for discs. I have no idea where to start? I've read through most of threads and I see no such conversation brewing. Anyone have a clue?
    Thanks, Much
  2. Jamie Miles
    Get the complete disc brake spindles off a '75+ Maverick/Comet or Granada. Bolt them on. Replace anything that needs it (calipers, brake pads, rotors). Use rubber brake hoses for a '74 Maverick with disc brakes.
    Have the front end alignment checked. Cruise.
    The hardest part will probably be knocking the ball joints loose.
  3. 1971 Mercury GT
    1971 Mercury Comet
    Thanks for the info!!
    Is there another alternative of upgrading if the parts were bought brand new?
  4. mean_maverick
    ceramic pads and slotted drilled rotors.. :huh: if that's what you mean then both are available thru alot of aftermarket companies
  5. mean_maverick
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    All new parts
    www.discbrakeswap.com
  7. cmain125
    cmain125 Member
    arizona
    72 grabber
    i just finished mine.. cost about 300 i used 73 mustang set up then i got new pads calipers and rotors.
  8. 1971 Mercury GT
    1971 Mercury Comet
    What was the hardest part about the upgrade?
  9. cmain125
    cmain125 Member
    arizona
    72 grabber
    we had a hard time for a while we didnt have the mustang proportioning valve so it was like there was air in the brakes and we had to shorten the ros to the master because the pedal was too high. i may have pictures tommorrow for you guys
  10. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    You can also use the Granada/Monarch porportioning valve. You can use the Maverick non-power disc master cyl for better peddle effort, but I just used the power disk granada master. I have not had a problem. I did the swap on my Falcon/Ranchero first. Have the parts for the Mav, just haven't done it.
  11. mean_maverick
    ive used the Granada prop valve on all of my swaps. i also have some for sale if interested
  12. Bryant
    i used the wilwood disk brake kit part number 140-9054. im using the stock drum drum master cylinder and distrubtion block for now. i can tell that the brakes drag for just a second when i release them so some day im going to replace the distrubtion block with a line lock on the front and a adjustable proportioning block for the rear. i also will replace the master with the 79 dodge truck master that willwood uses as there recomended master cylinder.
    this is a high performance option that onlys a little bit more than geting stock stuff and buying new calipers, rotors, pads, and bearings.
  13. cmain125
    cmain125 Member
    arizona
    72 grabber
    I was planning on using the granada stuff but the "mustard stain" stuff was avaliable so i took it.
  14. 1971 Mercury GT
    1971 Mercury Comet
    So In upgrading for the 1971 Comet I plan on using high performance disc brakes. Any recommendations. Something that is good bang for your buck.
  15. Bryant
    my willwoods as mentioned earlyer work great. affordable and stop way better than stock ever will
