Drive Shaft
Discussion in 'Technical' started by Camtemple, May 18, 2004.
  1. Camtemple
    Camtemple Member
    BC Canada
    Maverick
    I have a C4 and an 8" rear end in my car and I think the Drive shaft is out of blance because i'm getting signfigent vibration while driving at about 60mph. I was wondering if there was an aluminum drive shaft I could stick into it, or any other suggestions of possibly drive shafts that might fit.
    Thanks for the help.
  2. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Cam,
    I'm not aware of any aluminum driveshafts that will just "drop in". Why not just have your current driveshaft balanced?
    Also, make sure your wheels are balanced and tires aren't worn. This can cause a hell of a vibration as well.
    Sam :)
  3. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Check your U joints. Probably worn out.
  4. chandler
    chandler Member
    Warrenton Mo
    Maverick
    Along w/ the previous post's said also check the transmission rubber mount, it can be half torn and apear to be good, jack up on the trans. to check it:smash:
  5. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    The Ford Racing Aluminum Drive shaft for Fox Chassis `(79-93) Mustangs will bolt into a Mavcom after simply removing the Flange on the rear U-joint and replacing it with the correct U-joint.;)
  6. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Good info. Just so happens, I've got a Al DS for a Mustang Fox. (y)
  7. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    whats a trusted brand name for u-joints?
  8. Camtemple
    Camtemple Member
    BC Canada
    Maverick
    Thanks for the info. I just recently had the Tranny rebuilt so i would think that when the rebuilders built it they would have checked out all the stuff with the ujoints and everything like that. Its just that the shafts probably unbalanced Hopefully anyway. I also have brand new wheels and tires, and it vibrated on both the old tires and the new ones. So I don't think its that either... but thanks for the info.
  9. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    Make sure the u-joints are properly installed...a freind did that once trying to help me out. I'm using a 5.0L driveshaft in my '71..just changed the front u-joint and it fit perfectly...and they're cheap..
  10. Killercomet
    Killercomet Member MCCI
    Dirtyburg, WV
    1973 comet
    Wish I had known that I just ordered a Dynotech 6061 Alum. DS from Booze Brothers Perf. last week has upgraded u joints.1330s front and a stagerd 1330 1310 in the back.I could have saved some $$.The shaft I ordered was $350...
  11. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Brute strength or Spicer seem to be the best for performance. :smash:
