Drive Shaft stuck in Tail Shaft
Discussion in 'Technical' started by Comet4me, Apr 1, 2012.
  1. Comet4me
    Comet4me Member
    1975 Comet
    I'm removing the drive shaft from my C4. The C-brackets came out fine and the drive shaft dropped out easily. I tried pulling the yolk out of the tail shaft and it came out about halfway and stopped. Won't budge and am afraid to just yank it out because I don't won't to damage it. Why is it stuck and is this normal?
  2. injectedmav
    injectedmav Member
    Georgia
    Probably varnish on the forward section of the yoke. Does it rotate and just not come out or it is bound (won't turn and won't come out) ?
  3. Comet4me
    Comet4me Member
    1975 Comet
    I don't think it turns. In fact I don't think I could push it back in either. It started pouring rain out and had to come inside.
  4. Comet4me
    Comet4me Member
    1975 Comet
    Other than possible varnish, is there any other reason it should be hung up?
  5. Comet4me
    Comet4me Member
    1975 Comet
    Oh, its an inertia type yoke if it matters
  6. tomboy
    tomboy Member
    It could be that the bushing and yoke is gaulded.
  7. Comet4me
    Comet4me Member
    1975 Comet
    Never heard of that...gaulded?
  8. Comet4me
    Comet4me Member
    1975 Comet
    Ok, looked it up....don't like the sound of that....
  9. Comet4me
    Comet4me Member
    1975 Comet
    So if it's stuck and I can't get it out, should I try to put it all back together and drive it to a tranny shop, or can I do this in my driveway? It seems I have to drop the tail shaft in order to work on this properly.
  10. 71gold
    if it came out half way it's not...gaulded.
    it could be it created a vac. in the snout...:yup:
    try it again after it sits a minute. pulling on it will not hurt anything.
  11. baddad457
    Take a BFH and drive it out by hitting the yoke on the shoulder portion. Could be someone drove an old tailshaft bushing into the tail housing and it's now stuck on the portion of the yoke poking thru the new bushing. Or it may just be the fluid suction keeping it from coming out.
  12. baddad457
    It's "GALLED" ;) but I doubt that's the problem
  13. Comet4me
    Comet4me Member
    1975 Comet
    Ok, I will try again tomorrow if the rain lets up. I'll check in afterwards.
  14. simple man
    simple man Member
    Bunnell,Florida
    This should do the trick, but I'd use a block of wood to hit on. These will get varnish on them over time. Just " tap " on it with the block of wood and it will move slightly with each tap. Once you get it off, spray the splines with PB Blaster, or equivalent, and put it back on and pull it off a few times. It will loosen right up! :)
  15. Comet4me
    Comet4me Member
    1975 Comet
    One tap on the shoulder with a rubber mallet and Bam, its out. Was too easy, feel stupid for posting thread now, lol thanks all
