Drill Press
Discussion in 'Tool & Shop Talk' started by rthomas771, Nov 13, 2012.
  1. rthomas771
    I bought a drill press at the swap meet in Perry, GA last Saturday. The belt guard was missing so I made my own using what I had on hand. When it was all said and done…I ended up with a Rat Rod appearance. To make the hood…I used a hood from a ’96 Saturn. What other object could be more appropriate for a tried and true task. After measuring the dimensions and laying masking tape down to give me a straight line, I cut the hood with a cut-off wheel using my angle grinder. I made a makeshift brake from a piece of angle iron from an old bed frame and clamped together with Vise-grips and used a rubber hammer to fold the sheet metal. I used my “new” drill press to drill holes for the pop-rivets. The thin metal at the bottom side of the guard needed to be re-enforced to make it rigid so I use an aluminum brace from a wall mounted shelving. This also doubles as a handle to open the belt guard to change the drill speed. Again I used the drill press to drill holes for the handle. The hinge on the other side of the cover was enough to keep the metal ridged enough from flopping around.
    [​IMG] [​IMG] [​IMG]
  2. Craig Selvey
    There is probably somebody posting this thread on a Saturn Message Board so they can all cry that you cut up a Saturn hood. :rofl2:
  3. Earl Branham
    Lugoff, SC
    You gonna put Grabber stripes on it?
  4. simple man
    simple man Member
    Bunnell,Florida
    Nice job! :thumbs2: That's about the best use there is for a Saturn hood! That looks so much nicer than the top of a mailbox that my friend has on his! :)
  5. ptpdub
    ptpdub Member
    canada Sk.
    looks like it works like a charm!(y)
