drag car info pls
Discussion in 'Technical' started by Payette 302MAV, Feb 20, 2011.
  1. Payette 302MAV
    Payette 302MAV Member
    Payette Idaho
    1970 Maverick 302 painted Bahama Blue Metallic.
    hello im a college student going to cwi taking the automotive class and i have a project of car alignments. so picked a Maverick drag car since i own a Maverick. I was hoping i could get some good ideas from everyone pls on what good caster, camber, and toe alignments would be for a maverick. Please and thanks everyone
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Just for drag racing? I'd say 4-5° castor, 0° camber, and 1/8" toe-in...
  3. bmcdaniel
    Can you get 4*-5* caster? My strut rod's almost maxed out at 2 3/4*. Anywho, mine's set at 2 3/4* caster, 0* camber, 1/16 toe. Anything you can do to keep it going straight at high speed.
  4. Bryant
    you can put shims behind the front bolt in the upper control arm to get more caster than the strut rod will allow. also if you pull the strutrod all the way forward the tire may rub on the fender when turning.
  5. Payette 302MAV
    Payette Idaho
    thanks for the info guys that helps alot thanks
