Does anyone have the dimensions for depth of distributor gear?
Discussion in 'Technical' started by scooper77515, Jan 28, 2008.
  1. scooper77515
    I cannot find it in any of my books. Want to verify mine is positioned correctly before I turn over the engine.
  2. rayzorsharp
    Does it not have a pin in it? How could it be anywhere else?
  3. scooper77515
    The one that came off my new distributor (purchased about 4 years ago from O'Reilly) had a cast iron gear, with 2 sets of holes. One pair was a little bit higher (barely...but you can see that it is a bit higher) than the other.
    The new one I am using came with one set of holes, and I am "assuming" it is the correct height, but I just want to verify it before I screw something up.
  4. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    overthinking it
  5. scooper77515
    Really? I have seen that the dimension is important to prevent excessive wear, and have heard horror stories from a couple guys, and just wanted to "not have to worry about it"...
  6. Craig Selvey
    I have no idea what the depth should be......but I too have heard that it needs to be checked.
  7. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    MSD site will have it
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Gear Installation on MSD Ford Distributors​
    It is recommended to send your Ford Distributor to MSD to have a new gear installed. The installation
    process requires a press fit and the need for special tools to achieve proper installation without
    damaging the shaft, gear or housing. If returning the distributor to MSD is not an option, a
    quality machine shop may also be able to install your new gear.​
    AUTOTRONIC CONTROLS CORPORATION ​
    • 1490 HENRY BRENNAN DR., EL PASO, TEXAS 79936 • (915) 857-5200 • FAX (915) 857-3344
    FRM22770 Revised 05/01 Printed In U.S.A.​
    1. With the endplay of the distributor shaft removed, measure the distance from the bottom of the
    gear to the bottom of the mounting flange (Figure 1). It should be within the specifications
    shown.
    2. Scribe a mark on the shaft at the bottom of the gear. This will aid in the installation position of the
    new gear.
    3. Remove the original roll pin and remove the press fit gear. Use extreme care not to damage the
    end of the shaft where it meshes with the oil pump.
    4. Position the gear so the new roll pin will enter the shaft 90° from the original hole. (Lining up the
    original hole is possible, but a new hole will likely be machined.)
    5. Press the new gear into position on the shaft. Measure the distance as shown in Figure 1 before
    drilling the new roll pin hole.
    6. Carefully drill a 0.125” hole through the shaft using the gear as a guide.
    7. Install the new 1/8” spiral roll pin.​
    CAUTION: ​
    If the gear is installed improperly, severe damage to the distributor and/or engine
    block will occur!
    Press firmly
    to take out
    all end play
    before measuring.
    Thrust Collar
    4.005" Max.
    3.996" Min.​
    Figure 1 Gear Installation Specifications​
    On the MSD FE Distributor,
    PN 8594,
    the spec is:​
    3.045" - 3.050".
  9. scooper77515
    Just went from "simple" to "technical"...But that is what I was asking...
    EDIT--Measured out PERFECTLY!!! One less thing for me to worry about...
  10. bmcdaniel
  11. scooper77515
    They are pulling instead of pushing in the Ford Racing instructions, but probably comes out to the same numbers. I already have the dizzy back in, so I am going to assume 2 things, 1) that the numbers would be the same, or close enough to be safe using the push or pull method and corresponding numbers, and 2) that a pre-drilled gear would likely be drilled at the correct place giving me the correct distance.
    Still, I am glad I tested it just to make sure.
    Plenty of things to worry about when starting a new motor, this is just one less thing I need to think about.
  12. 71gold
    "(Lining up the
    original hole is possible)"
    thats what i did...(y)
    ...:drive:...
  13. bmcdaniel
    Yep, that's the difference. :yup:
  14. rolandag2
    rolandag2 Member
    Dickinson, TX
    1970 Maverick Grabber
    lining up the holes works if u pray but I have done several gear changes and have always measured I'm the one that told scott to check that measurement as it is critical for proper fit. the hole in the new gear is put there so you can have something to aid in the drilling of the shaft. some new gears don't come with any holes and you have drill thru the gear and shaft at the same time.
  15. scooper77515
    MOST new gears come with NO holes. I had to shop around to find one with the holes pre-drilled.
    I was just hoping they drilled it in the correct place.
