Do you have to bleed oil pressure gauges?
Discussion in 'Technical' started by Russ, Feb 21, 2004.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Me and a friend were discussing whether or not you have to bleed mech. oil pressure gauges. The ones that have the plastic tubing that goes from the engine to the gauge. Russ
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Interesting question.
    I am guessing no since it is not a sealed system.
    The air will make it's way back to the engine and
    will be released in the crankcase somewhere.
    Seth
  3. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    I didn't bleed mine and it works fine, the instructions didn't say anything about it either
  4. don graham
    i never bled mine either, however i did change the plastic tubing out for the copper line. if the plastic tubing breaks or cracks it will leak oil into the car. depending on where it leaks of course.:)
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    Ditto on the changing of the lines. I braided mine after frying an engine ater only 2 hours. Plasitc line melted on a hedder tube and pumped my oil all over the road and spun a bearing. Expensive lesson!! Scotty P
