disk brake
Discussion in 'Technical' started by jean282, May 3, 2006.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    hi i just started to do the conversion on my 71 comet but when i ordered my calipers didnt come whit the caliper brackets. anyone know where i can find them thank you
  2. Jamie Miles
    Alto, GA
    I've had a few
    Caliper brackets? You mean the backing plates? I'm surprised they didn't come with the disc spindles. Best bet would probably be to post in the parts wanted forum.
  3. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Where ever you sourced the spindles should have supplied the brackets. They are a set.
    The brackets don't come with any replacement parts.
    Go back to the yard you got the spindles from and get the brackets.
  5. koonswala
    koonswala Member
    Winnsboro, LA
    maverick
    the same thing here im bout to go pick up some for mine and do a all disc swap good luck
  6. blugene
    Three castle nuts and a brake line and take the whole assym!
    (Per side)
  7. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    i send a message at who sold me the spindle and he told me they are still available at napa and it is true at www.rockauto.com also
  8. ratio411
    ratio411 Member
    Pensacola
    I went there (rockauto) and didn't find one... :huh:
    http://www.rockauto.com/catalog/catalog.php?carcode=1132243&pgname=Brake%2FWheel+Hub
    Edit:
    Not at Napa either...
    http://www.napaautoparts.com/masterpages/NOLMaster.aspx?PageId=430&CatId=3&SubCatId=13
    Ask for one at a parts house. They will say either "dealer" or "junkyard".
    We know the dealer is out, so the yard is all you got.
    What did the seller do with them?
    It's not like he can use them without spindles, or you, spindles without brackets.
  9. rayzorsharp
    I've never known of these brackets to be available over any counter unless it was Ford 25-30 years ago. It's not an item that wears out so there would be no reason for anyone to produce or re-produce them. You can buy the calipers rebuilt all day long but not the bracket or dust shield. Definitely a salvage yard item.
  10. blugene
    I have delt with some parts personel who go the extra mile and find your part, even used junkyard stuff. They will buy it and mark it up. They really like it when it's a non wearing hard part, like spindles and axles etc... :drink:
  11. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    It's OK guys. He bought the spindles from me on eBay, which had the brackets attached. What he was actually looking for, and found at NAPA, was the caliper support spring and key, and the hold down bolt. It's all good now...
  12. Jamie Miles
    Alto, GA
    I've had a few
    Or you can just go out to the yard and get them yourself with no markup! :drink:
