Alright im pullin the disc brakes off a 75 mav to put on my 70 mav. i need the spindles and the tie rods, and was wondering if i can just climb underneath and seperate the tie rods from the center link and then just be able to pull the tie rod, spindle, hub and rotor, and brackets and lines off all in the one assembled piece? thanks for any info...
Yes you can remove as an assembly. The diificult part will be getting the ball joints & tie rod ends to pop free. Tap firmly with hammer on the ceter link where the tie rod goes through several times with a hammer. Same principal with the ball joints. Good luck.
