disc brake conversion
Discussion in 'Technical' started by hallguy, Oct 15, 2007.
  1. hallguy
    hallguy Member
    So Cal
    73 Maverick, 79 Ranchero, 70 shelby gt 350 convertible
    I installed front disc brakes from a 71 grabber on my 73 with full manual drum brakes. Now it has no braking power and will not lock up. The only master cylinders I could find were full manual drum and power disc. I went with power disc. Is there a manual disc brake master available? I hate to go through the process of reflaring lines again if I dont have the correct master cylinder. Any ideas?
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If all else is in good order, you could need a drum/disc proportioning valve.
    Either that, or go with an aftermarket adjustable.
    Btw: No Maverick/Comet came with disc brakes until 74. They weren't standard issue till 76.
    You got discs off the Grabber that originally came off something else! ;)
    I would go down to the parts house and get a manual disc master for 76 Mav.
    That would get you right on the master.
    If that doesn't help, then shoot for a Granada prop valve or aftermarket adjustable. The aftermarket ones are inexpensive. The factory version will have to come from a donor car, I don't believe they are available new anywhere.
  3. 71gold
    Earl, and I put a new master cyl. on his car and had little to no brakes...it was a ...bad...new master cyl.(not rebuilt) :yup:
    ...:party3:...
  4. Dave B
    I put front disc's on my 73 Grabber, and left everything else stock drum, and they worked fine, drum master cylinder, drum porp valve. I used rebuilt 74 maverick calipers, with new rotors and pads on 75 Maverick spindles.
