disc brake conversion questions...
Discussion in 'Technical' started by random hero, Aug 8, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    ok so i have the spindles and all, i'm just not sure what hoses i need(can i use my stock ones?) i know i need a disc drum master but i've read u can use the drum/drum proportioning valve. also what tie rod ends do i need...my spindles are from a 78 granada...do i need those(these are female thread as opposed to male...i would imagine alignment would be a problem) any help is appreciated...thanks in advance
  2. Dave B
    Get some hoses for a 74 Maverick, with disc's.
  3. maverick maniac
    maverick maniac Banned
    owensboro ky
    tie rod ends from a Granada they are bigger then the maverick ones hoses are the same on both cars
  4. random hero
    hudson valley
    1972 maverick
    do i need granada tie rod ends since i have a granada spindle?
  5. maverick maniac
    owensboro ky
    yes i have sold dozens on e-bay
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I don't know about that. I used 77 Granada disc on mine, and used 71 Comet manual tie rods on a manual center link. They fit fine. There may be some that are bigger, but mine were not.
  7. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    I think it's hit and miss on the tie rod ends. When I put the discs from a '77 Granada on my 74 my tie rods fit and mine's got power steering. My car didn't have a proportioning valve, only a distribution block. I think the master cylinder that's on mine is a disc/drum one any way, bit I also put discs on the back and the rears will lock up first. I have an adjustable proportioning valve to put in but I'm waiting to hear back from Wilwood about what mc they reccomend so I can do it all at once.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I didn't have to change my tie rods, I have a manual steering
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    My stock tie rods fit but when I tightened down the castle nut the cotter pin didn't do any good any more. The taper was smaller on the early tie rod end.
